PXI
Acronis Activation Code
Were is the activation code for Acronis located when you receive a PXI controller (8108)?
(4,549 Views)
Please review the following document on Hard Drive Recovery and OS Installation for PXI and VXI Controllers.There is an image already accesible on the hard drive. By pressing F4 when prompted, you can enter the Acronis utility to perform a reinstall from this original image.
Ali M
www.ni.com/support
(4,539 Views)
Tried that, Looks like acronis is not running but is installed.
(4,535 Views)
If you are trying to restore the NI 8108 controller to its default factory settings, were you able to select the Restore option on the Acronis utility? Where in the process outlined in the knowledgebase are you observing a problem? Please clarify
Best regards
Ali M
www.ni.com/support
(4,517 Views)
