PXI
Adjust chassis power
I have a PXIe-1062Q chassis that the inhibit switch LED flashes red. It flashed red with or without module in the chassis. The +5V at the voltage monitoring connector measures 5.3 VDC. The acceptable voltage range as stated in the PXIe-1062Q User Manual is 4.75 to 5.25. Will a voltage of 5.3 cause the inhibit switch LED to flash red? Can the 5V be adjusted?
(3,230 Views)
Hello KBart,
I hope you were able to resolve this, but yes a small change in voltage coming from the power supply will cause the LED to flash red causing a problem.  As this is such a small offset, it could potentially go away once your power supply cools down a bit.  This voltage is not adjustable, but is a symptom of a malfunctioning power supply.  Good luck in your endeavors.
ColeR
Field Engineer
(3,160 Views)
