PXI
Any PXI 5411 Arbitrary waveform generators available to buy
Hi All
This is my first post on the NI forums.
I am after 2 good, new or used, PXI 5411 arbitrary waveform generators.
The reason i need the PXI5411 is because I have a system that relies on the parallel DIO outputs of this device.
Tim Streeter
(3,071 Views)
Tim,
To talk to a National Instruments employee, go to www.ni.com/contact.  On the left, you can either call the listed number (888-280-7645), or have a representitive call you.
Josh W. | National Instruments | Applications Engineer
Josh W.
Certified TestStand Architect
Formerly blue
(3,061 Views)
