PXI
Are analog out signals considered floating?
I want to use a PXI-6733 to output voltages and then measure those voltages using a PXI-6289.  In cofiguring the measurement on the PXI-6289, there are the choices of Referenced Single Ended, Non-Referenced Single Ended, and Differential.  So is the analog output of the PXI-6733 considered floating or ground referenced?  Which would be the best setting for the PXI-6289 analog input channel?  Thanks.
(3,223 Views)
Set your analog input as Reference Single Ended for your AI channel.
NI-khil
(3,209 Views)
