PXI
Are the read and write operations atomic for an array in a local variable.
I would like to know when you access an array in a local variable, is it an atomic operation?
Mat
(3,575 Views)
Hi Mat,
Are you talking about Labview ?
What do you mean with 'Atomic'
(3,570 Views)
Yes labview.
If you don't know what atomic means, here is a link: http://en.wikipedia.org/wiki/Atomic_(computer_science)
I think that in labview read and write operations for any scalar (int,single,double...) are atomic. But I'm not sure it is for arrays.
Mat
(3,569 Views)
I think it depends on what level you look at it. I assume you are referring to the application level on which LV operates.
I think you are right for the numbers, but operations on arrays can't be as one operation simply because it can take to long.
May I ask why you ask this ?
(3,560 Views)
(3,549 Views)
