PXI
Ballard MIL STD 1553 error 403002 when using a FIFO buffer for messages
Hi. I use PXI Ballard MIL STD 1553 board LV-222-555-555, LabVIEW 2015 x32. Driver "Astronics-Ballard-LabVIEW32-1.2.0.2"
My task is to use messaging using scheduler and trigger start. I am using the example "Example 10 - External PXI Trigger". As long as the number of messages in the FIFO buffer is set to 1, everything is working, there are no errors.
 If I set the FIFO to a value other than 1, I get error 403002. I tried to change the frequency of exchange, the number of words, and so on - as soon as I turn off the buffer (FIFO=1), the program works. Who has any thoughts on how to fix them?
Message 1 of 1
(189 Views)
