PXI
Basics of PXI system architecture
Hi
Can anyone suggest some links wher i would have the information about the PXI systems, its bus architecture and how this is useful in instrumentation.
(3,571 Views)
Hi Gops,
This links should give you a good starting point:
http://www.ni.com/swf/pxi/us/launch.htm
http://volt.ni.com/niwc/common.jsp?page=pxi_what_is&node=1525
http://volt.ni.com/niwc/common.jsp?page=pxi_right_choice&node=1525&node=1525
Luca
Luca
(3,571 Views)
Hi Gops,
Luca suggested some great sites for PXI. I would also suggest you check out the PXI Systems Alliance webpage at www.pxisa.org.
David Shatila
www.ni.com/support
(3,571 Views)
