PXI
Bias remains of output of PXI5412
Hello everyone,
In my test setup I'm using a PXI5412 to generate a arbitrary waveform (one specific pulse) and apply this signal to a device. With a PXI5105 I measure the response of the device. After this I move to the next device and repeat the measurement (with the same waveform).
My problem is that their remains a DC bias on the output of the PXI5412 after doing a measurement which influences the next measurement (even when the arbitrary waveform ends with 0V). The strange thing is that this bias seems to vary random after each measurement between -1.5 V and 1.5V.
Can anybody tell me why this DC bias stays on the output after a measurement?
Kind regards,
Patrick
(4,651 Views)
Hi Patrick,
Does the same thing happen if you try to output a wave made up of all one value (eg. 1V). If not you could do something similar at the end of each waveform to force the output to a known value.
Al C
National Instruments,
Application Engineer
(4,583 Views)
