PXI
Blue screen of death when running labwindows, pxi chassis, and windows 2000
Hi, when programming under labwindows the software crashes cvi, and windows NT and i get the blue screen of death...usually every hr or so. I checked the hw config and there are no conflicts. Is it normal to share IRQ 9 for all? is there a document that explains the I/O map addresses for the pxi to check for conflicts? I got all NI instruments, but one irig board. Currently only talking to the DMM and the switch.
(3,511 Views)
Many of the IRQs in a system get shared, so I do not see that as a problem, especially since there are no conflicts in the device manager. The I/O ranges that are set are the ones that you needs to use. I think that the errors you are getting are more than likely something to do with you program. Do you know which card you are communicating with when it fails?
AndrewM
(3,511 Views)
me also
-win2000
-cvi 6.0
-pxi1006 8176cpu
-dmm4060
-IVI1.83 ,nidaq693,nidmm201,nidmm21
- break program after a nidmmread function
- terminate program
- rerun program
- DMM Blue Screen of Death..everytime
- Make Software User Friendly -
(3,511 Views)
