PXI
Bluetooth Analysis Interactive Example: won't connect to PXIe-5644R
The data sheet for the Analysis Toolkit indicates compatibility, but the canned example won't connect to the module.
I need this to evaluate the system, and I won't have the eval long enough to write a whole test suite in labview.
Note I get is "Error:  Device identifier is invalid."
(4,790 Views)
Hello engineer27,
What version of the NI Bluetooth Analysis Toolkit do you have?
Can you please post an NI MAX Technical Support Report? This will help me ensure that you have software installed correctly, as well as determine how your PXIe-5644R is named in NI MAX. Here is how to generate a report: http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4
Oftentimes that error occurs when you are using inproper channel syntax for the device. Can you please post a screenshot of your device's alias in NI MAX, as well as your LabVIEW Front Panel where you are typing in the Device Identifier?
Physical Channel Syntax: http://zone.ni.com/reference/en-XX/help/370466V-01/mxcncpts/physchannames/
(4,530 Views)
BT Toolkit version is 14.5
Support report is attached, as are screen caps.
In the analyzer window, there is an option to "refresh list" in the list box, but it has no entries.
(4,516 Views)
The Bluetooth toolkit relies on the NI-RFSA driver. Your current version of NI-RFSA does not support the PXIe-5644R. Please upgrade your version of NI-RFSA and it should work. You may have to repair the Bluetooth toolkit after installing the newer driver.
(4,487 Views)
