PXI
Brand new PXIe-2746 failed self test
My brand new PXIe-2746 switch fails the self-test in MAX and returns the following error:
The self test failed.
Error description not found
Error reported by the instrument driver: -240039
I'm on Windows 10, PXIe-1082 chassis, and I'm using the latest versions of the NI PXI Platform Services, as well as NI-SWITCH.
Does anyone know what the error is due to? I can open the Soft Front Panel and switch all the relays - I can hear all of them click which seems to indicate that the board is working properly. I have not yet ordered the required MCX cables so I cannot test the board myself as of now.
Michael
Message 1 of 8
(4,638 Views)
Additional information: I controlled the relays using the NI-SWITCH Soft Front Panel (Schematic tab) and tested the conductivity with a voltmeter. Everything works as expected, so I am not sure why the self-test fails.
Message 2 of 8
(4,605 Views)
Does the PXIe-2746 return the same error in every slot of the chassis?
Could you attach an image of the chassis on NI MAX?
Message 3 of 8
(4,595 Views)
Hi Michael,
It would be great if you sent a screenshot of the self-test so we can check it!
Message 4 of 8
(4,584 Views)
Hi capuy26,
I have uploaded a screenshot of the failed self-test.
Thanks!
Michael
Message 5 of 8
(4,575 Views)
Hi KRojas,
I haven't tried all slots, but I've tried in a hybrid as well as PXIe slot, and the results were the same.
I have attached a screenshot of the PXI chassis slot details in MAX.
Michael
Message 6 of 8
(4,574 Views)
Hello and happy new year everyone!
I have a new element: I ran NI Switch Health Center and got the following error message: no supported NI resources were detected. I checked the help file which indicates that the PXIe-2746 should be supported though.
It looks like this is a driver problem, but since I've already removed and reinstalled the NI SWITCH drivers, I'm not sure what to try.
Any suggestion is highly appreciated!
Michael
Message 7 of 8
(4,525 Views)
Hey Michael, are you sure that it is compatible?
I found this online, it may help!
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000004A8rSAE&l=en-US
Message 8 of 8
(4,499 Views)
