PXI
CAN I USE PXI-8330 WITH PCI-8331
CAN I USE PXI-8330 (CHASSIS) WITH PCI-8331 (PC)?
CAN I USE PXI-8331 (CHASSIS) WITH PCI-8330 (PC)?
CAN I USE PXI-8110 (CHASSIS) WITH PCI-8330 (PC)?
DOES CONTROLLER MUST BE SAME MODEL?
(3,914 Views)
Accepted by topic author ASHOKKUMAR2014
HI,
the MXI controllers have be used in pairs like you can see you the manual on page 1-4.
http://www.ni.com/pdf/manuals/370840b.pdf
PXI-8110 is a PXI controller, so its a computer doesn´t need be conected to a PC using a MXI-card.
Abel
NI Brazil
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(3,909 Views)
