PXI
Calibration
If  I sent a 5650 signal generator in for calibration and the firmware changes but we do not update the IVI driver will we run into issues using the signal generator?
(5,377 Views)
You should be good, the IVI driver should be compatible with the 5650 without any upgrades.  What version of the driver do you currently have?
David B
(5,365 Views)
