PXI
Calibration
Hi all, do the PXI-6542 waveform generators require annual calibration?
(1,275 Views)
This article explains how to obtain the calibration interval,
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1xHCAQ&l=en-US
Santhosh
Soliton Technologies
(1,262 Views)
As always.. it depends ...
If you use it as a source for something concerning quality, you will need to calibrate it. Usually you have someone around with a quality badge 😉 , who should be able to answer that question in detail. Finally the assesor (ISO XXXXX) will tell you 😄
Say you use it in a EndOfLine-tester to provide signals and you read the response:YES    but if you also read the generator output with a calibrated ADC .. maybe NO (but the ADC needs to be calibrated)
The periode also depends on how you use it and a risc analyses, manufactor documetation and (documented) instrument history ...
What is your application?
Greetings from Germany
Henrik
LV since v3.1
(1,250 Views)
