PXI
Can 781xR support bidirectional
Can 781xR support bidirectional?
If not which one can support bidirectional with 25 MHz clock?
(4,025 Views)
Hey SMO33,
I assume that when you say bidirectional you mean can each line be configured individually as an input and an output.  If that is what you meant the answer is yes.  One of the strengths of using a DAQ device with an FPGA on is that the digital inputs and outputs are all completely reconfigurable which allows for a lot of flexibility in usage.
If you are interested in getting more information about FPGA devices, I would encourage you to take a look at our website about the uses and characteristics of FPGAs.
(4,014 Views)
I mean bidirectional as in  the use of I2C bus but with 25 MHz clock (Send and recieve in the same line at the clock cycle level)
(4,011 Views)
Yes it can support Bi-Direction, but one direction at a time. I created I2C protocol using 2 pins of FPGA; one for tranmitting and one for receiveing , just like in original I2C bus. It's two wire protocol.
(4,002 Views)
