PXI
Can I change two DC fans in PXI-1042 chasis?
Can I change two DC fans ( Mechatronics E9225X)in PXI-1042 chasis?
It is too noisy in a quiet environment.
Could you reveal what kind of DC fans were adopted in the PXI-1042Q chasis?
(3,728 Views)
Hello
This is a great question and I’m regretful to mention that we cannot release this information. The PXI-1042Q has much more than different fans. There is an elaborate scheme of sensors. With the two different systems there is a vast amount of temperature requirements and sensors to control the fans. This conversion could be harmful to your system and not an issue National Instruments can support.
CMartinez
(3,708 Views)
Do you mean the only key to 1042's annoying noise is to buy a new 1042Q chasis?
Oh My God!
(3,708 Views)
As Chris stated, the 1042Q acheives reduced noise by changing the fan speed based on intake temperature. It is not simply a change of fans that changes a 1042 to the Q variety.
(3,702 Views)
Unfortunately this is the only option that we will support. I apologize but changing the fans could have far greater consequences than benefit.
cmartinez
(3,684 Views)
