04-17-2007 03:59 PM
04-17-2007 11:52 PM
04-18-2007 06:50 AM
04-18-2007 08:45 AM
Ralph,
If you are referring to the ExpressCard slot (i.e., the slot characterized by the interface described at www.expresscard.org), then yes, in general you can hot-swap modules in this slot. However, there must be enough free resources available to configure a newly-added device, and sometimes this is not the case. For non PCI Express aware operating systems like Windows XP, the BIOS must explicitly allocate resources ahead of time for devices that may be inserted into an ExpressCard slot while the system is running. If a BIOS does not do this allocation, then many modules won't function without an additional reboot because the OS can't find system resources to configure them.
Hope this helps,
Eric G.
