PXI
Can I use NI 5761 and NI 7954R on PXI chassis to work as an oscilloscope?
Hi all,
       Is it possible that we use NI 5761 digitizer and NI 7954R FlexRIO to work as an oscilloscope? I know there are some PXI oscilloscope modules. I am wondering whether we can use the 5761 digitizer to work as an oscilloscope. If it is possible, is ther any access to the labview and fpga code?
       Thank you very much.
(4,937 Views)
Hello qdlpavel,
Have you looked into the NI5761 - Getting Started example project? You can find it from LabVIEW by navigating to Help » Find Examples. Then, with the NI Example Finder open, search for 5761 and the Getting Started example project should show up.
dK
(4,910 Views)
