PXI
Can I use PXI embedded controller connected to PC under LINUX OS
Dear all,
 We ara trying to connect PXI8106 (in Chassis 1042) to PC under LINUX via ethernet (cross cable for the moment), the labview version is 8.5.
Can I use PXI embedded controller connected to PC under LINUX OS  ?
if yes, where can I find .ini file for its configuration ?.
Thanks in advance.
(3,784 Views)
Accepted by topic author bachir_elec
Hello bachir_elec,
I am sending you two links that I am sure that give the information you need.
Using Linux on a PXI Embedeed Controller:
http://digital.ni.com/public.nsf/allkb/821E0C115A3B4EF286257069004B8352?OpenDocument
Configuring your PXI System in Linux:
http://digital.ni.com/public.nsf/allkb/5CEEC941FB7B0488862573F700653B21?OpenDocument
Can you take a look?
Antonios
(3,776 Views)
Thanks alot A. V.,
The second link that's realy what I need :).
(3,772 Views)
