PXI
Can I use PXI module(PXI-6722) and DAQmx(USB-6210) at the same time?
Now, I'm using the USB-6210 alone for 10-channel analog inputs.
I want to make multi-channel analog output(at least 8 channels), then I found PXI analog output module(PXI-6722).
As my experience, two DAQmx-USB modules cannot use at the same time(on single labtop).
So, my question is that I can use those two modules (6210 & 6722) simultaneously with well synchronized condition?
And, for using PXI module, I have to mount it on desktop not labtop?
If there better option for my experiment setup, please let me know.
Thank you.
Message 1 of 1
(1,928 Views)
