PXI
Can I use data files to control the analog out of PXI-6733?
I am new to NI products. I'd like to know if I can use data files(like txt file which contains some amount of data) to generate arbitrary waveform. If this can be done, are there any other file formats can be used to generate arbitrary waveforms?
NA
(3,793 Views)
Yes you have do read the file in LabVIEW and convert that into waveform and send it to the PXI target. Normally we use to generate arbitrary waveform (non standard waveform) in this method only then send the waveform data to the target.
(3,790 Views)
Thanks for reply! I'd like to know if there are some other data file formats can be accepted by LabView besides txt...
(3,787 Views)
