PXI
Can a DAQ-mx Task contain channels from a Pxi-6143 and a Pxi-4472?
If you are planning on driving the number of relays that you described then a high channel count relay module would be best for that application.  You could programatically control the relays all with one device and it would be seamless in software as if would require only one task.
Thank you,
Justin
Justin
Product Support Engineer - Conditioned Measurements
Message 11 of 11
(752 Views)
