PXI
Can a PXI chassis power supply be replaced?
I have a chassis (PXI-1000B) with a cactus power supply and I'd rather not have to shell out for a brand new chassis if at all possible.  Are replacement shuttles available?
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(3,065 Views)
Howdy crelf,
Depending on the type of PXI-1000B chassis, a replacement shuttle may be available through the RMA process.  I'd suggest calling NI support directly and setting up a service request at 1-866-275-6964 to check about this issue.  I'd like to also point you to the KnowledgeBase article What Type of Fuse Is In the DC Power Supply Cable of the PXI 1000B? if you'd like to do some additional troubleshooting.  Have a great day!
Sincerely,
Chris G in AE
(3,041 Views)
