PXI
Can an ATI force/torque sensor be used with PXI 7358?
I have a PXI 7358 controller card and I'm looking to get a Mini40 force/torque sensor from ATI (manual: http://www.ati-ia.com/app_content/documents/9610-05-1017%20DAQ.pdf).
The force sensor manual says that I need to use an NI M-series or E-series DAQ card. The force sensor output looks to be analog voltage on a 68 pin connector. I know the PXI 7358 has a few analog inputs, but less than 68. Does anyone know if the PXI 7358 can be made to work with this force sensor?
Or, what is a good PXI DAQ card that will work with this force sensor?
Thank you.
(4,024 Views)
Hi MatthewG,
Please do not double post.  See my response here.
Stephen Meserve
(4,012 Views)
