PXI
Can someone help me get the lock in amplifier start up kit working?
I can see the "reference" signal and the "signal" signal in the scope mode, so I know the software sees the 4472 board, but I don't see: Reference Frequency, X, Y, Aplitude (R), or Phase. I removed the license check vi and I altered the Param value. These are the only changes that I have made. The program asks for the license check vi when i start the lockin demo vi, but I select the option of running without it. I'm using LabVIEW 7. I'm attaching the Start Up Kit program that I have altered and that I'm trying to run. The signals I put in are from optical detectors and both the signal and the ref are 100 Hz and about 30 mV peak to peak, but I can make them whatever I want. I just want to see th
e program work. I'd greatly apreciate any help. Thanks
Message 1 of 1
(3,267 Views)
