03-20-2009 11:31 AM
I just recieved a PXI-1036 Chassis connected to a computer with a MXI-4 card. I'm trying to get set up, and went to identify the chassis in MAX, however, when I right click on the model and go to "Identify As..." and select my chassis model, it doesn't allo me to save my indentification. I've downloaded and installed the "PXI Platform Services 2.4.2", but nothing changes. Can anyone help?
03-25-2009 04:51 AM
Hello.
In which order do you turn on your chassis and you computer? You have to reboot the computer AFTER the PXI chassis.
Are your MXI card and the other cards correctly seen under Windows device manager? Have you installed NI-VISA?
Regards.
03-25-2009 09:01 AM
Yeah, I turn the chassis on first, before the computer, and NI-Visa is also installed. Here are screen shots of my Device Manager and my MAX showing the NI software installed.
03-26-2009 08:53 AM
Hello.
When you say that you can't save your configuration under MAX, do you mean that the save icon is dimmed?
In all the cases, I rather suggest you ton contact NI support, and I think it's the best way to solve quickly your issue. In which country are you?
Regards
03-26-2009 12:58 PM
Yeah.. I mean that the save icon is dimmed.. and when I select the chassis with the drop down box, the selection doesn't get saved (i.e. if I switch to a new window and come back, it still says that its Unrecognized.
For the country, I'm actually in Paris France.
-Sidney
03-27-2009 09:40 AM
Hello.
If you're in France, you can call 0157662424 and ask for a service request. I think It's the best solution.
Regards.
06-03-2010 02:50 PM
Was this problem ever resolved? I am having the same problem. Thanks.
06-03-2010 02:56 PM
No, I never resolved it as I needed the thing immediately for our work.. so couldn't deal with their support delays. I manage to program and use the FPGA, but I havent't ever put more cards in the PXI chassis either though.. so who knows how that'll work out.
I'd be curious to hear if you ever figure out the problem though. Thanks
