PXI
Can't add MXI Chassis connected to RT PXI to a LV Project
I have an MXI chassis connected to an RT PXI.  On the host machine, I can see both the RT PXI and the MXI chassis and can access the MXI FPGA to flash a bitfile, etc.
But in my LV project, I cannot add the MXI FPGA target.  I can only add the RT PXI but attempting to add the MXI target under the PXI yield no FPGA device found.
I saw my father do some work on a car once as a kid and I asked him "How did you know how to do that?" He responded "I didn't, I had to figure it out."
(2,937 Views)
Which MXI chassis model, PXI chassis, PXI RT controller and LabVIEW version are you using?
Do you have LabVIEW FPGA module and LabVIEW RT module installed?
Regards
Gustave
(2,917 Views)
PXI Chassis: PXIe-1085
PXI Controller: PXIe-8880
MXI Card: PXIe-8364
MXI Chassis: NI-9157
LabVIEW 2017 SP1 f1
LabVIEW RT 2017
LabVIEW FPGA 2017
PXI Platform Services Runtime and Config 18.0
NI-RIO 17.6
(2,915 Views)
Accepted by topic author blackburnite
So I don't know for sure what the issue was, I think whoever set this system up when it arrived in shipping, connected everything in whatever order and had the PXI powered before the MXI chassis was connected.  This would I think cause the BIOS to configure the PCI bus incorrectly.  So I removed power entirely from the PXI and rebooted witht he MXI chassis already connected and powered.
But I also removed all software from the PXI controller and re-installed so it's possible the cause was somewhere there.
In either case, after doing the above two actions, the MXI chassis now is recognized in LV.
(2,903 Views)
