PXI
Can't detect PXIe-8880 after updating from pharlap to windows 7
Hello
I've been updating a system from PXIe-8880 from using pharlap to windows 7, as a mean to use more modern versions of veristand with it, however, no system is detected as a remote device from the computer in the lab. I've updated firmware, installed network drivers, and deactivated firewall in both computers, but i havent had any success, and MAX won't list the PXIe device as detected. I've been wondering if anyone has had that problem, or if i'm missing any installation in my PXIe device.
Thanks in advance.
(678 Views)
Veristand runs on an RTOS. Did you really upgrade the RTOS that is meant to run the Veristand model to Windows 7 (non-RTOS)?
Santhosh
Soliton Technologies
(654 Views)
Only controllers installed with Real Time Operating System (Pharlap ETS or Linux RT) can be detected as a remote system under NI MAX.
The controller installed with Windows has no difference from any other Windows desktop or laptop.
You cannot deploy a VeriStand project to a remote Windows target. When using Windows, you can only deploy a VeriStand project locally. Note that you will lose the determinism when using Windows vs a RTOS.
https://tmesystems.net/
(629 Views)
