PXI
Can't start my NI PXIe-6345 : error -88716
Hello everyone, I've searched a little and I've come to the conclusion that there is a version mismatch between two elements.
NI just delivered me a full PXI system mounted : PXIe-1078 with controler PXIe-8821, all cards seem ok except the two 6345 with the error. I'm asking you because I haven't figured out certainly what is the other element which is not in the right version and how tu upgrade it.
Is the the 8821 version ?
I've installed the driver NI DAQmx 16 which was on the CD given by NI ...
Thanks for your lights and time !
Mathieu
(2,914 Views)
Accepted by topic author M.athieu.
Well I found the solution :
http://digital.ni.com/public.nsf/allkb/D170D1AF82303EA086256B4200780579
The NI DAQ mx driver on DVD is a 16.0.1 and there was a 16.0.0 on the 6345 installed ...
(2,868 Views)
