PXI
Can you use both GPIB and Ehternet on the same PXI-8232 in the same application?
We have an application that uses PXI chessis and various PXI cards in aadition to a PXI-8232 card. The Agilent power supplies use the GPIB port on the PXI-8232. We have a motion controller with an ethernet connection. My question is can we use the ehternet port on the same PXI-8232 card? If not, which is a better option, another PXI-8232 or a PXI-8231? Thanks
(4,600 Views)
Hi ekramul1,
Yes you should be able to use both the GPIB and ethernet ports on your PXI card for your application.
(4,577 Views)
