PXI
Cannot simulate PXI-8513
Hello, I tried to create a simulated PXI-8513 with MAX to test CAN BUS protocol but I can't see PXI-8513 card in MAX.
I installed NI-XNET 20.5 according to my environment compatibility (Labview 2017).
Message 1 of 8
(1,581 Views)
NI-XNET devices cannot be simulated, unfortunately.
https://tmesystems.net/
Message 2 of 8
(1,552 Views)
Thanks for your answer.
How can I test a CAN BUS TX/RX without the hardware device? Can I do something like a loopback?
Message 3 of 8
(1,532 Views)
No, you cannot test CAN communication using NI-XNET without actual hardware. You need actual hardware to do loopback.
Message 4 of 8
(1,521 Views)
Is it possibile with NI-CAN ?
Message 5 of 8
(1,511 Views)
NI-CAN does support virtual devices.
However, NI-CAN is obsolete and not recommended for new development. Although you can run the NI-CAN API on an NI-XNET device using a compatibility library, not all features are supported.
Message 6 of 8
(1,500 Views)
Is there a way to test that I can write a proper frame with my .dbc ?
I mean a vi that:
1) loads .dbc
2) takes an float value
3) displays a proper CAN BUS frame just before physically transmits it.
Message 7 of 8
(1,441 Views)
I mean a vi that:
1) loads .dbc
You can use the XNET Conversion Session. See the shipping examples for reference.
Message 8 of 8
(1,425 Views)
