PXI
Changing the duty cycle for the square wave in fgen
Hi.  I'm trying to generate a square wave with a duty cycle of 25%.  I have configured the 5412 fgen to be using high resolution sampling.  How can I change the default duty cycle of 50%?
(3,448 Views)
What is the software that you are using?
labview,labwindows,CVI ?????
If you are using labview/labwindows, the example programs for function generator come with a variable duty cycle option for a square wave generator
regards
(3,443 Views)
Thank you.
(3,437 Views)
