PXI
Chassis Compatibility check
Hi all,
Wanted to do a quick sanity check. We're considering purchasing a new chassis, the 1095 with timing & sync. Is this chassis compatible with our older PXIe-430X and PXIe-6683H cards?
(1,982 Views)
PXIe-430x is compatible with 1095, are you sure you have got a PXIe-6683H?
If 6683 is a PXI version, it may not fit into the Timing Slot (slot10)
Santhosh
Soliton Technologies
(1,969 Views)
Hi Santhosh,
Thanks for your response!
It's the PXI-6683 Hybrid card, my understanding was it could fit into any of the Hybrid slots on the 1095?
Amy
(1,957 Views)
It can fit into a regular PXI or PXI-Hybrid slot but you cannot use PXI_STAR triggers or replace PXI_CLK10 as described in the user manual
Santhosh
(1,951 Views)
I thought I could connect it via SMA to the 10 MHz ref in on the back of the chassis?
(1,948 Views)
Accepted by topic author AmyWalton
Correct, you can use those to use external 10MHz reference
Santhosh
(1,932 Views)
Brilliant, thank you!
(1,927 Views)
