PXI
Chroma 52912 get voltage
Hi Sir,
You know, the Chroma 52912 is used in PXI chassis, has the function of enable voltage, which will apply the voltage to device.
Also has the function of get voltage, this is read the voltage of the device ?
At this moment, the DC source is still on to device ?
Thanks.
Keep moving
(1,989 Views)
I believe all functions are described in below document.
https://chromaus.com/manuals/5291214Manual.pdf
(1,751 Views)
