PXI
Combining MXI-4 with 665x
Hi there
This is my setup:
Master PXI-Chassis:
- Holds PXI Controller in Slot 1
- 18 Slots
- Several Modules
Slave PXI-Chassis:
- NO PXI Controller
- 18 Slots
- Several Modules
Now this is my question:
Can i combine data transfer with synchronisation? I mean, can i use MXI-4 connectors (PXI-833X) with NI-Sync (PXI-665X) at the same time?
I need to synchronize PXI_CLK10 and SampleClock and share PXI_STAR trigger lines between the modules in both chassis while using ONE SINGLE controller.
Is this possible?
Thanks a lot in advance..
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(4,034 Views)
Accepted by topic author chrisger
Hi chris,
what you are trying to do should be possible. Please see e.g. this tutorial: High Channel High Performance Multi Chassis System
As you can also see in this post, you will need a master 665x module and a slave 665x module in order to synchronize the various PXI lines.
As is referenced in the post above, the KB 2WF8F22L gives a good overview of synchronization techniques.
If you need more information, please don't hesitate to ask.
Regards
Peter A.
Field Sales Engineer, NI Germany
(4,007 Views)
Hi Peter
Thanks a lot for this information.
Best regards
chris
(4,004 Views)
Sorry, wrong solution 😉
Best regards
chris
(4,002 Views)
