PXI
Configuring a PXI-8145RT controller
I''m trying to re-configure a PXI-8145RT with LabVIEW 2009.  I was able to install all the software I needed on the controller.  But in MAX 5.0 I see my controller as a PXI 8140RT.  I also have a MIO 6041e in the right most slot of my PXI-1052 chassis, which I can see in MAX.
My problem is when I'm try to create my PXI SCXI 1052 chassis I'm getting the following error "Please connect your PXI chassis or identify it correctly in the PXI section of MAX".  I don't know what to do now... 😞
Any help?
Michel
(4,823 Views)
Hello Michel,
Does your chassis show up correctly in MAX? When MAX correctly sees the PXI chassis, you will be able to add the SCXI part. If you do not see the correct chassis, you will get an error when you try to add the SCXI chassis. If you see the wrong chassis, delete it and add the correct one.
Maggie
ni.com/support
(4,796 Views)
