PXI
Connecting PXI Express Chassis to Electronic load
I need help, I am going to buy PXI express chassis (eg. PXIe-1082) and measurement card (eg. NI PXIe-6368). I want to connect it to test bench for PEMFC, which will include electronic load. Now I want to ask you question. Is it possible to connect chassis to electronic load? I am going to perform dynamic impedance measurement (all frequncies will be studied in the same time) so normal EIS module can not be used. Electronic load needs to have analog input and output? All of them has "Analog Programming" connection. Can someone explain me what does it mean exactly? Or maybe someone know electronic load, to which I will be able connect PXI express chassis? Thank you in advance for help 🙂
Message 1 of 1
(2,923 Views)
