PXI
Connection between Arbitrary Waveform, NI FPGA PXI 7841R and an Oscilloscope
Hello Family,
I am working on generation of abitrary waveform generator with limited knowledge on connection and setting up of NI equipment.
I have a non NI arbitrary waveform generator that is used to generate a programmed waveshape. I want to be able to feed this signal from one of the channels of the arbitrary waveform generator to one of the I/Os on the NI PXI 7841R FPGA. However, I don't know how to do this connection since the two devices have different connections. Aside these I also have an NI PXI 5154 digitizer and 2 SCB 68A connectors.
Also, I will like to get the processed signal through LabVIEW on the FPGA from the output of the FPGA to the input on the oscilloscope. The oscilloscope is also a non NI oscilloscope.
What connectors will I need to be able to achieve a connection between the standalone non NI arbitrary waveform generator and PXI 7841R FPGA and also between the FPGA and a standalone non NI oscilloscope.
In short, I want connectors to be able to implement this block diagram per the attached image.
Thank you.
(830 Views)
Accepted by topic author lquarshie
NI 78xx Models: R Series Cable and Accessory Compatibility
Connect SHC68-68-RMIO and SCB-68A to PXI-7841R.
Use BNC-to-Wire connector to connect the waveform generator and oscilloscope to the SCB-68A terminal block.
https://tmesystems.net/
(792 Views)
I tried to get the FPGA to be able to output 1 from a Control with input as 1 on an Indicator but got the error attached as the image.
What am I doing wrong? I tried changing the name of the resource to the FPGA's name but also got another error.
(712 Views)
