PXI
Connection from PXI-8186 to USB
I use PXI-8186 and LabView-2010.
 I have third party devices with USB-interface.
Can the PXI-8186 processor operate via a USB interface  by VISA subVI ?
I can work with USB devices connected to a Windows + LabView computer.
VI VisaFind sees instruments connected to the computer, but does not see instruments connected to the PXI controller.
(954 Views)
PXI-8186 is an embedded controller, in layman terms, a compact computer fit inside the PXI chassis.
You can use the 8186 just as a regular computer by connecting keyboard, mouse, monitor and networking. Just like a regular computer, you can connect USB devices (or instruments) and run application on the computer to control these instruments.
Does this answer your question?
Santhosh
Soliton Technologies
(940 Views)
Thank you.
I don't use this controller as a regular computer.
It does not have Windows installed. It has the Labview-RT system installed.
I work through a local network.
The VISA package is installed, it works correctly through the GPIB interface.
I don't know how to add the USB driver.
(908 Views)
Control a USB Device with NI-VISA on a Real-Time Controller
https://tmesystems.net/
(895 Views)
