PXI
Considering the PXI-8420/16 as a solution for running one application to communicate to multiple devices.
I am developing an application that needs to communicate through a serial interface to several devices under test at the same time.Would the PXI-8420/16 be a solution??
(4,716 Views)
Unfortunately, our serial cards do not do serial communication concurrently.
Randy Solomonson
(4,716 Views)
If the NI serial cards do not do concurrent communication, then how do they work? I have a similar application but the communication doesn't necessarily need to be concurrent. It just cannot be sequential. Maybe the NI serial cards will suit my needs but I need an explanation of their operation before I can determine that.
(4,716 Views)
