01-10-2013 03:19 AM
A test I am performing requires me to perform continuous data aquistion after an intial start trigger, using using PXI 6556. Is this possible? If so could you tell me how?
Also, is it possible to fetch data from the PXI memory to the PC while data acquisition is taking place?
Thank you in advance for your time,
Best Regards,
Arjun
11-12-2015 04:38 PM
Yes.
There are several good examples in the Help----Find examples--- HSDIO.
