PXI
Control PXI devices via PyVisa?
Is it possible to control PXI devices via PyVisa in the same way as USB, and GPIB devices?
Message 1 of 8
(9,715 Views)
Accepted by topic author k-rhyme
Hi k-rhyme,
It should be possible to do. You can definitely control PXI devices using NI-VISA and since PyVISA is just a Python wrapper, it should be possible. It also depends on the version of VISA that PyVISA is using. I would recommend looking at the NI-VISA User Manual for more info PXI specific functions.
Using the NI-VISA Driver Wizard and NI-VISA to Develop a PXI(e)/PCI(e) Driver in Windows
https://www.ni.com/docs/en-US/bundle/ni-visa/page/using-visa-driver-wizard-to-program-pxipci.html
NI-VISA User Manual
https://www.ni.com/docs/en-US/bundle/ni-visa/page/user-manual-welcome.html
Message 2 of 8
(9,695 Views)
Thanks Frank, I was unfamiliar with register based communication on NI devices.
Message 3 of 8
(9,691 Views)
The PXI devices I have are the PXI-e 4143, and the PXI-e 4145. How would I perform simple tasks such as reading and writing voltages and currents using register based communication?
The documenation is very clear about how to read and write arbitrary data to the register, but it is not clear as to how that data can be useful.
Message 4 of 8
(9,678 Views)
If you want to do analog acquistion with Python, you may want to consider PyDAQmx. This is a wrapper for the NI-DAQmx driver, which is built for data acquisition. This would be easier than using VISA calls.
PyDAQmx
https://pythonhosted.org/PyDAQmx/
Message 5 of 8
(9,668 Views)
Thanks! I will try this.
Message 6 of 8
(9,664 Views)
It would appear that PCIe 4143 and PCIe 4145 devices are not supported by NI-DAQmx. Will support for these be added in the future, or am I limited to LabVIEW and LabWindows for development with these devices?
Message 7 of 8
(9,649 Views)
Ok, sorry about that. Unfortunately, it seems you need the NI-DCPower driver to operate those. Your development options for this driver are LabVIEW or LabWindows. You could use the C API in LabWindoes if you want to use the C language.
Download the NI LabWindows™/CVI Free Trial
https://www.ni.com/en/support/downloads/software-products/download.labwindows-cvi.html
Message 8 of 8
(9,608 Views)
