PXI
Control default state of PXI_Trig
Hardware: PXIe-1095
I struggled to find documentation on the default state of the PXI_Trig lines but ran across something in ni_sync documentation that stated they were default high. I did some testing and found this statement to be true. Not to get into details, but this causes some issues for my hardware under certain conditions when disconnecting immediate routing. Quick fix is to forget disconnecting the route and just leave it routed.
Is there any method for controlling the default state of the lines and setting them to default low?
-Matt
Message 1 of 1
(384 Views)
