PXI
Controlling a PXI-4461 in a C++ program
My goal is to create a standalone program that can control a PXI-4461 from a C++ program.  I am using the following hardware: PXI-1056, PXI-6652, PXI-4461, and PXI-PCI8336.  I looked at the “C Function Reference Help” and I'm starting to understand how to measure and source the PXI-4461.  How do I call the self calibration from my C++ program?
(4,503 Views)
I just found the "NI-DAQ™mx C Reference Help"  that contains the self calibration functions I was looking for.  What is the minimum install needed to use my hardware in a standalone program?  Can I just add a couple of dlls, or do I have to do a full NI install?
(4,500 Views)
Accepted by topic author Eagle01
This is the smallest redistributable for DAQmx. It has a much smaller footprint than the full version but does not include MAX.
CTA, CLA, MTFBWY
(4,498 Views)
Is it possible to just install the windows drivers(.sys) needed by me hardware
(4,393 Views)
The runtime engine is the lowest install level offered by NI.  You could make sure you are just installing support for C# to make sure any extraneous stuff is not included.
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(4,369 Views)
