PXI
Conversion of raw signal(e.g Temperature) into voltage.
In case of conversion of analog signals, i.e. scaled signals into electrical signals,
When I set the max-min range of the signal as default one, my application runs properly. But when I change it to some other value, it doesn't work for gain other thatn default.
(3,220 Views)
Hi Gaurikul,
Can you tell us which device are you using and what is the gain that you are setting.
Hardik
(3,196 Views)
