PXI
Cooling system of NI PXIe-1088
Does anybody know if the fans are pushing air into the device or do they pull it out of the system?
(891 Views)
The fans pull in air from underneath the chassis, pushes the air upwards across the modules, and exhausts out the top of the chassis.
(879 Views)
Figure 7 shows that the air exhaust vent is on the top.
National Instruments PXIe-1088 User Manual (Page 12 of 26) | ManualsLib
https://tmesystems.net/
(876 Views)
Thank you. Is it the same with the power supply?
(875 Views)
