PXI
Copy file from PC to PXI via Ethernet
Hello there,
I am new to PXI. I need to copy a config file, located in a known folder on a PC that connect to PXI via Ethernet, to the PXI's hard drive.
I want to know if it is doable and how to do it.
Thanks!
(3,456 Views)
Hi LUX_
I'm afraid I might need some more information from you to fully understand what you are trying to do. Often
times, users will want to transfer DAQmx devices or tasks/channels in MAX to your PXI chassis. If this what
you are wanting to do, you can simply Export and Import files using the steps listed in this article: http://digital.ni.com/public.nsf/websearch/4363A9766216C40886256E930070861D.
If this is not what you are trying to do, please answer the following questions.
What type of configuration file are you trying to copy and why?
Is your PXI chassis using MXI (connected to a host PC) or an embedded controller?
What operating systems and NI software are you working with on each computer?
(3,444 Views)
