PXI
Create an executable for a RT project
Hi all, I am not sure on how to create an executable of a real-time VI. I have read about using source distributions but I have not yet used it. Can you send me some suggestions about this?
Claudio
Message 1 of 12
(5,448 Views)
Hello hex_cro!
Thank you for posting your question in this forum!
Below I am sending you a link to a tutorial: "Deploying and launching a Real-Time Application." that explains everything about creating an executable targeted either to your RT controller or to your host PC. It is very clear and I am sure that it will help you! If you have any further questions don't hesitate to ask!
https://www.ni.com/en/support/documentation/supplemental/11/using-application-components-to-deploy-l...
Antonios
Message 2 of 12
(5,439 Views)
Hi Antonios, I've already seen this tutorial, but it's about Labview 6.1 and earlier and I'm using Labview 2010. Any suggestions?
Claudio
Message 3 of 12
(5,437 Views)
Great, then you can also check the LabVIEW 2010 Real-Time Module Help which is located in the link below!
It explains step by step the things you have to do in order to complete this task.
https://www.ni.com/docs/en-US/bundle/labview-real-time-module/page/creating-stand-alone-real-time-ap...
Let me know if this helped you or not!
I think that there will be no problem!
Cheers!
Antonios
Message 4 of 12
(5,433 Views)
Thanks! I've already tried this and this generates a rtexe file. Is possible to launch the execution of these file from a VI placed on the host. I mean, I'd like to create a .exe file from host VI and call executable of real-time VI.
Claudio
Message 5 of 12
(5,431 Views)
Yes you are able to do what you explained above by programmatically launching the executable or vi on your Real - Time Controller.
At start, you just have to create a source distribution (right click on Build Specifications--->New---> Source Distribution)--- instead of creating an application (right click ---> New ---> Real Time Application). In this way Labview creates a folder in which there are contained the main vi and all it's dependencies (subVI's, libraries).
Then, you have to transfer through File Transfer Protocol (FTP) this folder to your RT Target.
After you made these steps, by using an Open Application Reference VI and  Open VI Reference VI on the Block Diagram, you are able to set the RT Controller Name or IP of RT target, as well as the location of the top level vi in your RT target
Finally, you can use an Invoke Node or a Call By Reference Node to run the remote VI.
You can find very little detail and images of the description above in the link below:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIE4CAO&l=en-US
You can also check the example in Labview  Example Finder " Vi Server.lvproj" that basically does all the above and I am sure it will help you.
Does this work for you? Let me know!!
Antonios
Message 6 of 12
(5,426 Views)
Hi Antonios,
I have already problems...can I send you real-time VI and host VI in order to check it?
Claudio
Message 7 of 12
(5,391 Views)
Hello Claudio 🙂
Are there any errors obtained when you try to run the vi?
Yes of course, you can send me a copy of your host and real time vi to take a look and tell you my opinion!
Cheers!
Antonios
Message 8 of 12
(5,389 Views)
Can you send me an e-mail address where can I send my VI?
Claudio
Message 9 of 12
(5,387 Views)
You can send your vi here in public and then I will download it in order to check it!
Please tell me what kind of problems you have. This way it will be easier for me to reach a possible solution!!
Antonios
Message 10 of 12
(5,384 Views)
