PXI
Creating triggers from Labview FPGA to timing module NI PXIe 6674T in Flexrio
Hi all,
I have created a program in Labview FPGA to start a counter everytime the
trigger button is enabled as shown in the attached file.
I want to send a trigger signal to the PFI 3 slot of the NI PXIe 6674 timing
module embedded in the NI PXIe 1075 chassis such that it triggers the Keysight arbitrary waveform generator to transmit a waveform.
As I am new to labview fpgaam not able to figure this out.
Any help would be appreciated
Aishwarya
NI Software :  LabVIEW FPGA Module  version 2012 SP1
NI Hardware :  PXIe-1075 device
(3,045 Views)
A great starting point would be the following tutorial:
Designing Custom Triggering Applications With the LabVIEW FPGA Module
https://www.ni.com/en/support/documentation/supplemental/21/designing-custom-triggering-applications...
Finch Train
(2,999 Views)
