PXI
Creating voltage pulse
Attached program is to generate voltage pulse to measure current and voltage of the device under test. Does anyone know how can I see the pulse output? In the attached VI which is a example code from Labview, I tried to see the pulse output in a waveform graph but nothing work. I am very much new in the Labview, If anyone knows how can I retrieve the pulse output from this VI it will be really helpful.
(2,121 Views)
Hi Marzia, I couldn't launch your VI because my LabVIEW is version 2017.
Did you refer following example code?
NI Example Finder -> Hardware Input and Output -> Modular Instruments
-> NI-DCPower -> NI-DCPower Pulse Voltage.vi
Does your SMU generate pulse as you expected? Do you see the pulse with Oscilloscope?
How do you measure the generation?
Certified LabVIEW Developer
GCentral
(2,058 Views)
